Connecting the Edge Gateway to a Remote Device (BGP over LAN)
For LAN-side connectivity, you can connect the Edge Gateway to an external device, such as a LAN BGP router.
Field Description Name
Connect Local Gateway To
Field Description Remote LAN IP
