For LAN-side connectivity, you can connect the Edge Gateway to an external device, such as a LAN BGP router.
  1. In CoPilot, navigate to Networking > Connectivity > External Connections (S2C) tab.
  2. From + External Connection To dropdown menu, select External Device, then provide the following information.
    Field Description
    Connect Local Gateway To
  3. Click + Connection and provide the following information.
    Field Description
  4. Click Save.
